43H Brakes Frozen
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Dave K on April 26, 2000 at 08:12:58 from (166.72.175.246):
I have been able to remove the brakes from the left side but the right side is a different matter. The pin that attaches to the brake compression spring is frozen to the cover and apparently the other end is frozen to the transmission case. So far I have applied WD 40, beat on it, and put a pipe wrench to it to no avail. If I could just free up where the pin passes through the cover, I can probably deal with the other end after removing the cover. I'm sure others have experienced this same problem and hopefully solved it. Any advice and suggestions would be greatly appreciated.
Post A Followup
: Re: 43H Brakes Frozen
