Re: Charging questions
Posted by Jg20601 on December 04, 2009 at 22:36:20 from (63.28.121.42):
In Reply to: Charging questions posted by J Wilbur on December 04, 2009 at 16:42:12:
You may also want to check to see if the alternator and bracket is grounded to the tractor. Some Pontiacs had a problem like this and they added a small ground wire from the bolthole at the back of the alternator to the engine block. You can test it with a jumper wire with alligator clips. Just make sure it is a very short bolt if you end up installing a ground wire.
