Re: 52 M Not Starting
Posted by riverbend on December 05, 2009 at 11:21:43 from (208.160.33.214):
In Reply to: 52 M Not Starting posted by Bemidji 52 M on December 05, 2009 at 10:57:38:
I start my H by pushing in the clutch (so it does not have to move all that cold grease), closing the choke, giving it a couple cranks with the ignition off. Open the choke, open the throttle 6 or 7 clicks, ignition on, and crank. Usually it fires right away. Then I have to catch it with the choke to keep it from dying.
What are you doing to start your M ?
Greg
