Re: 52 M Not Starting
Posted by Tom Fleming on December 05, 2009 at 11:27:21 from (206.193.247.91):
In Reply to: 52 M Not Starting posted by Bemidji 52 M on December 05, 2009 at 10:57:38:
One thing to check is make sure your aircleaner has fresh, clean oil in it, and that is at the right level.
I ran into a Cub once that was flooding and wouldn't run for a crap. When it did run, it ran VERY rich.
Fiddled with the carb, same result. Pulled the bottom off the air cleaner, and it was so full of crud, it was more like grease than oil. Turned out, it was starving for air......like running with the choke on. Cleaned her up, fresh oil, and it ran like a top.
This may not be your problem, but I would sure check it out.
