Posted by El Toro on December 05, 2009 at 16:48:41 from (74.103.74.58):
In Reply to: 52 M Not Starting posted by Bemidji 52 M on December 05, 2009 at 10:57:38:
Are you sure you're getting gas into the engine. From what you say about removing the plug it should've been wet with all that cranking. You need to hold your hand over the throat of the carburetor while someone makes an attempt to start the engine. There should be good suction on your hand. If there's very little suction that's a sign you have low intake manifold vacuum. Do a compression check and see what the readings are. You may have worn rings and sleeves, valves not seating. You need good compression, fuel and ignition to make it run. When was the last time it ran? Hal
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
