IHC 240 12 volt conversion
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Gene Crawford on April 26, 2000 at 09:25:08 from (204.29.113.2):
Got another question on my 12 volt conversion. I got the wiring diagram from Bob M. and have installed everything up to the switch and warning light.
Since I am electrically and schematically challenged, I need more help!!!
First, my 240 has a push button ignition and an on/off switch. Both switches have two terminals.
What I need to know is where both switches go in the wiring diagram. Also, I have an external solenoid which is mounted on my starter.
I hooked up the wire from my ammeter to the same terminal as the battery. There is another wire going from the solenoid to the starter. There is also a smaller terminal on the solenoid. What do I connect to this terminal?
The last question I have is regarding the warning light. I have read some information saying to hook up a diode in that position. Do I need the warning light or the diode? Which would be preferable?
If anyone can help me I would greatly appreciate the assistance.
Gene
Post A Followup
: Re: IHC 240 12 volt conversion
