2 Bad gauges?
Posted by Machine249 on December 07, 2009 at 14:03:40 from (76.100.246.141):
I need help with my fuel gauge. I have a new sending unit and have tried two differant gauges with the same result. Everything is wired correctly and all wires check out as far as current (no shorts). Every time I hook it up, no matter the float position, it will bury on full. I have checked the ground on the sending unit wire at the gauge with a test light and get very dim on empty and bright on full. Am I correct to assume that I have tested two gauges with the same problem? If so where can I get a new gauge. Thanks for any help.
