Re: 2 Bad gauges?
Posted by Brownie 450 on December 07, 2009 at 15:02:45 from (66.43.241.141):
In Reply to: 2 Bad gauges? posted by Machine249 on December 07, 2009 at 14:03:40:
What is this on? Can you put your meter on ohms & move the float through its range & see what the meter reads. This would be taken with leads attached between the "hot" terminal & the flange of the gage. Make sure no other wires are attached when doing the resistance check.
