Re: 1970 - 444 gas IHC - No Start
Posted by El Toro on December 07, 2009 at 15:01:53 from (74.103.74.58):
In Reply to: 1970 - 444 gas IHC - No Start posted by rlm2139 on December 07, 2009 at 12:56:37:
You may have a vacuum leak, make sure the intake manifold is tight & the carburetor. Hold your hand over the throat of the carburetor and see if there's good suction on your hand. You may need a helper to try & start the engine. If you have a distributor you need to be sure you're getting battery voltage to the coil with the points open. That's on both small terminals.
Use a volt meter or a test lite. Hal
