Re: M overhaul---advanced questions
Posted by Andrew Z on December 10, 2009 at 17:48:46 from (64.252.130.179):
In Reply to: M overhaul---advanced questions posted by zooeyhall on December 10, 2009 at 17:39:44:
i would deff do the wrist pin bushings they need to be remened out to fit the pin. as for the crank you can check them in place with a micrometer but if it have never been turned down before it will most likly need to be done. the head i would say is up to you. if its not leaking coolant then you dont have to but if it was me and i had it all apart then why not its not very expensive to have it done. also dont forget cam bearings as well they may need to be replaced too.
Andrew
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
