Posted by zooeyhall on December 10, 2009 at 17:39:44 from (74.46.125.189):
I"m thinking about overhauling my Farmall M this winter. The last time it was done was back in 1984. I use it to farm 160 acres so it has had some real hours on it since that time, and it"s starting to use oil.
I know all about replacing the sleeves, pistons, rings, bearings, valves etc. But wanted to know if I should do some other things. This is the third time this tractor will be overhauled, and as I mentioned she is still a working girl and does some heavy crop tillage (mostly tandem disking in the spring and also planting).
For example: should I get the connecting rods and/or crankshaft or block magnifluxed? Should the connecting rod bushings be replaced? This will be the third time the head and block mating surfaces will be smoothed-down. Is there a limit to how many times you can do this? Are there any other things I should do over and above the standard overhaul? Thanks for any advice and it is appreciated!
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
