Re: M overhaul---advanced questions
Posted by ChadS on December 11, 2009 at 08:39:16 from (4.225.89.117):
In Reply to: Re: M overhaul---advanced questions posted by SUPER TRUCKER on December 10, 2009 at 18:06:55:
To use the 450 rods,
You would have to find a set of pistons from a 400 C-264, with a 4 inch bore, and uses the small diameter wrist pin.
You wont find a 4 inch bore M-SM with a small pin in any overhaul.
Unless it was for the 400 with a 4 inch bore and small pin. If something like that exists for the 400, then thats a good option. Only other way is to bore the block, install 450 sleeves and got to the 281ci.
ChadS
