Re: 450 tachometer
Posted by D Slater on December 11, 2009 at 12:34:54 from (72.65.148.173):
In Reply to: 450 tachometer posted by danto on December 10, 2009 at 19:13:14:
You will be lucky if the old gear is good. If you have the slotted gear housing, I'm pretty sure you can't get a replacement gear for it. IH came out with a new gear retainer, housing and gear to replace those with. Think the only thing you can get now is the gear for the new type housing and it doesn't fit the old type housing. Although I did modify one to work before. Package 369694R91 replaced 364829R91 and contained the new type housing,retainer and gear. New gear was 369695R91, housing 369692R1 and gear retainer 369693R1. Think the gear may be all you can get now. New type housing has the gear drive hole centered and smooth on the outside. New gear has a metal cover on the shaft, instead of the all plastic shaft on other types. Late 450 tractors used the new type.
