450 tachometer
Posted by danto on December 10, 2009 at 19:13:14 from (72.160.46.47):
Tach wasn't working on this Farmall 450 I just bought. Took the cable loose at the tach, and tach turns freely and needle moves. Cable looks good. Took the drive mechanism out at the distributor and with the gear out and hooked up to the cable, I can turn the gear and the tach needle moves. So wondering why it doesn't work when gear is in place to the distributor? Does the plastic gear get worn and needs replaced? Any ideas? Thanks!!
