Thanks for the reply Armand, Let me get this right. All I need to do is switch the control valve to "S" and then just connect the hydraulic line from the plow cylinder to the top hydraulic line on the valve? Or does it matter what line on the valve I connect to? I didn't see any info in the manual on how to connect the lines. Maybe I am just over thinking this hookup.. But want to be sure. Thank you.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
