Re: Farmall 460 Gas
Posted by Armand Tatro on December 15, 2009 at 05:32:55 from (71.201.22.21):
In Reply to: Farmall 460 Gas posted by BenB on December 14, 2009 at 12:38:38:
Block both rear wheels and jack both front wheels off the ground and turn the steering wheel. Let us know the results. It is possible to take the steel lines loose at the pump and with the help of adapters connect them to the remotes of another tractor. This will only circulate the oil. To steer the tractor you will need a helper to do the steering.I will look at my 560 Farmall for more ideas. If it is the front axel is froze or stuck the best thing to do would be to remove the wide front and replace with a tricycle front to get the tractor into your shop. Where are you located? Armand
