Posted by Wardner on December 15, 2009 at 20:02:10 from (4.154.245.208):
In Reply to: Re: hydraulics help posted by Wardner on December 15, 2009 at 19:23:50:
After re-reading the thread, I noticed that you said "IH 400". That's not good enough. Is it a Farmall or International? If it is an International, you can't do what I photographed in the previous picture. The bolster gets in the way. You could still use the Prince PTO pump.
If it is a Farmall, your cheapest solution is to go to a salvage yard and get the flow control valve, the three work valves and levers, the two center positioned manifolds w/outlets, and maybe a new pump. I am not confident that three valves can be fitted to an International. The cowl only has holes for two valve linkages.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
