Posted by gene bender on December 17, 2009 at 01:21:57 from (67.55.226.179):
In Reply to: My Super C won't start posted by TreeFarmer1414 on December 16, 2009 at 17:39:46:
You will have to remove radiator and steering sector before removing the crank pulley. Then you will see what teethand where they are all missing. The front pulley needs a bearing splitter to put behind the pulley as its a press fit then use a three jaw puller. The crank gear is also a press type fit and will need to be heated to remove. Used parts can be found easy. Ifn ya cant get them local i would have them. You should buy the I@T manual it shows how the timing marks line up. Does the gov shaft need re-bushing as i also do them. Sure makes a difference in throttle response w2hen things are in shape.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w
... [Read Article]
Latest Ad:
[More Ads]
