Posted by TreeFarmer1414 on December 16, 2009 at 17:39:46 from (66.158.169.71):
In September when using the Super C, it started to tick. The tick gradually elevated to a knock. It got to the point where I shut the tractor off and it would not re-start. Two weeks ago, I finally took time to check things out. The rotor in the distributor was not turning. So yesterday more wrenches and I started to take things apart. Ended up taking the governor housing off. The 33 teeth gear has eight consecutive missing teeth. You can see at least one broken tooth on the matching 66 tooth camshaft gear as well. What's the chance the 33 tooth gear on the crank also has missing teeth? How difficult is it to repair? Will these parts be hard to find? Would it be easier to replace the whole governor assembly and not just the gear with the missing teeth? Will the front tires and pedestal have to be removed? I know these are way too many questions but this will be my maiden voyage on this type of repair. How does everything get timed when putting it back together? I am sure there will be more questions. But, then again, you guys can sure be helpful with the answers. Thanks in advance for your help.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
