You're using "pressure" and "flow" interchangeably. They are two different things.
I take it the snowblower is rated for 11-12GPM and 2000PSI?
I also take it the tractor is rated for 17GPM and 2000PSI?
2000PSI is 2000PSI, regardless of flow. Your hydraulic system is providing the correct PRESSURE.
If they are telling you that you have too much pressure, ask to speak with someone else. The person you are talking to does not know what he is talking about.
The only thing you can do inline is reduce flow. They make flow-limiting valves that are fairly inexpensive.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
