Re: My Super C won't start
Posted by El Toro on December 17, 2009 at 17:17:06 from (74.103.74.58):
In Reply to: My Super C won't start posted by TreeFarmer1414 on December 16, 2009 at 17:39:46:
You may need to bring No1 piston to TDC on the compression stroke when you get the new parts installed. Then see where your rotor is pointing
it should be at the No1 plug tower. If its off you will need to pull the distributor and rotate the rotor so its at the No1 plug tower. Hal
