Posted by teddy52food on December 21, 2009 at 17:07:01 from (209.237.111.169):
In Reply to: C-175 crankshaft posted by loafersglory on December 21, 2009 at 15:57:48:
Chads has good advice. Also make sure the crank is ground the full length of the bearing. Loosen the cap a little at a time until you can turn it over . Then take it apart & see if there is a tight (drag) spot on a bearing. If there is you will have to find out why. Don't put the engine back together as the bearing has to be free. No breaking in. If you have the crank out ,torque the caps without the bearings. Get a good straight edge & try to see if the block is straight. It may need line boring. Please let us know what you find.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
