C-175 crankshaft
Posted by loafersglory on December 21, 2009 at 15:57:48 from (72.71.207.217):
I am installing a crankshaft in a C-175 engine. The crank has been reground and the bearings sized for crank. Specs are “max main clearance .0055” and “main run clearance .0011 - .0041”. Using plastigage and torqueing the oiled bolts to specs, clearance on all three bearings is .003 - .004. After the plastigage has been removed and the bolts retorqued I cannot turn the crank by hand. If I torque only bearings 2 & 3 and leave 1 loose I can turn crank by hand. Bearing 1 has the least clearance of all .004. Will I have a problem with this? Will the crank/bearings need to “wear in”?
