Re: C-175 crankshaft
Posted by Owen Aaland on December 21, 2009 at 20:14:27 from (65.165.246.148):
In Reply to: C-175 crankshaft posted by Bob on December 21, 2009 at 15:57:48:
ChadS said: (quoted from post at 20:50:38 12/21/09) ........
If the front or rear main cap gets swapped, it wont spin. tangs on the bearings sit together so if one is turned backwards it wont spin. It should spin freely,,,, also check all of your bearing part numbers,, make sure they are all the same part number and size. .......... ChadS
On most IH engines the main bearing tabs DO NOT go together on the same side. Make sure you have the cap on the correct way before you do anything irreversible like polishing the bore.
