Posted by El Toro on December 22, 2009 at 04:17:10 from (74.103.74.58):
In Reply to: C-175 crankshaft posted by loafersglory on December 21, 2009 at 15:57:48:
Your main bearing caps should have a number on them and that number faces toward the cam shaft. Look on the back side of the new insert bearings to see if they have the correct undersize marking on them for the reground shaft. If they reground the shaft to .020" undersize your inserts should have that on the back side of the inserts. If they are the correct bearings and your caps are on correct and you can't rotate the crankshaft by hand I would take the block & shaft back to your machine shop. I think you should be able to rotate that crank with only .002" clearance on the bearings. Hal
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
