Re: 856 transmission problem
Posted by trulyred on December 23, 2009 at 13:13:46 from (216.252.3.187):
In Reply to: 856 transmission problem posted by joe blow on December 23, 2009 at 12:12:53:
If the low side of the TA (mechanical sprag) is good the tractor should move with a good main clutch. The high side (clutch pack)can slip due to low pressure from a weak pump or a leak. The only simple solution would be if the dump valve or its linkage is binding. The dump valve is the one connected to the clutch linkage with the 1/4" x long rod. Unfortunately when what you"ve described happens it is due to leakage inside the TA unit. If your power steering is working OK then you probably need a TA replacement. Many times guys don"t realize their TA is "OUT" on the low side because they will move a light load but not a heavy one.
