Posted by joe blow on December 23, 2009 at 12:12:53 from (74.220.14.47):
I have a 856 that will not move with a load. When I let out the clutch peddle the tractor does not move for a second or two, then it will drive ok with no load. I put a new clutch in, I changed the trans filter, and I changed mcv pump(where I got the pump they only had the gasket to mount the mcv valve to the trans, so I did not take the mcv totally apart, but I did pull some off the springs and they seemed to be fine) It is the same with the TA lever forward or back. I thought the TA would not slip in direct. I added 5 gal hyd, it is a little over full. I pulled the filter thinking I may have pluged right away, but It didn't look pluged. The oil probbably could be changed but I dont think that is the problem. Any help will be appreciated.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
