Posted by trulyred on December 23, 2009 at 13:27:42 from (216.252.3.187):
In Reply to: 706 loader plumbing posted by Rtkman706 on December 23, 2009 at 12:58:01:
Works fine to tie the lever either way, swapping the hose outlets changes direction of flow. Probably works best to tie back due to float position in full forward. However!!! is your loader control valve "open" or "closed" center, for older IH's it needs to be for open center, that means oil must flow through the system when the loader valve is in neutral. There are plugs that you install or remove according to what you have. If it came off a JD it will need to be changed.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
