Posted by Rtkman706 on December 23, 2009 at 12:58:01 from (207.119.188.128):
I finally got the hydraulic fittings fixed on my loader. Now it's time to plumb everything. As others have mentioned, I have 3 sets of hydraulic ports, 1 on each side of the steering column and 1 in the rear.
I plan on using the left steering column ports with my external loader valving (1 lever-bucket control, 1-lever-lift control, 1 lever for future grapple).
My questions:
1) Do I just tie back the left hyd lever?
2) Does it matter which hyd port I use (ie should the top port be the inlet or outlet going to the loader valving)?
3) Do I have to do anything special to the draft controls during loader operation?
Thanks.
This post was edited by Rtkman706 at 12:58:14 12/23/09.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
