Re: 706 loader plumbing
Posted by Rtkman706 on December 23, 2009 at 13:35:37 from (207.119.188.128):
In Reply to: 706 loader plumbing posted by Janicholson on December 23, 2009 at 12:58:01:
trulyred said: (quoted from post at 22:27:42 12/23/09) Works fine to tie the lever either way, swapping the hose outlets changes direction of flow. Probably works best to tie back due to float position in full forward. However!!! is your loader control valve "open" or "closed" center, for older IH's it needs to be for open center, that means oil must flow through the system when the loader valve is in neutral. There are plugs that you install or remove according to what you have. If it came off a JD it will need to be changed.
It's an older Schwartz 2070 loader, which supposedly came off a 966, not sure about the open or closed center.
