192? mccormick deering (farmall)
Posted by John LORNE Simmons on December 24, 2009 at 12:20:41 from (204.237.5.164):
i have had this ,i've been told by no expert mind you that it is a 1928 mccormick deering(farmall)International row cropper he called it.
it has steel wheels,the fronts are close together and the rears are 11' wide from outside to outside with 2 rows of 8" kleats,it has 2 gas tanks and some kind of manifold switchover,you can start it on gas then switch it over to diesel or whatever,the steering shaft goes the full length of the hood an hooks into a tower at the front,at the bottom of the tower is a shaft with 2 cables hooking into it and 1 cable runs down each side hooking into the rear brakes,you can turn the front wheels sideways and what ever way you turned {R-L} it pulls the cable on that side and locks the brake on that rear wheel causing tractor to go in circles,the tractor did run until 2008 then it was parked over the winter(we live in canada so winters are long and cold)and in the spring it was seized,my question is can anyone out there tell me the exact year of it and the approx.value if i was to decide to sellit thank you....J.Lorne Simmons
