Re: super c crankshaft pulley
Posted by ScottyHOMEy on December 24, 2009 at 18:44:12 from (70.105.248.61):
In Reply to: Re: super c crankshaft pulley posted by CNKS on December 24, 2009 at 18:24:26:
It's kind of like aligning a clutch disc. The seal around the pulley is mounted in the timing cover. You don't want it flopping and shifting around on its own, but you want to leave the timing cover loose so that you can shift it to center the seal around the pulley.
The threads are good for drawing it down. Using them certainly is better than beating on it, which can damage the thrust surfaces of your main bearings, though a light judicious tap wouldn't hurt any.
I've never been able to get one off without heat. It takes a lot less to got it back on and I've just always found the job goes better having heated it.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
