That's a Charlynn output shaft coupling. Unlikely the CIH dealer will have a replacement. However an aftermarket parts dealer that stocks Charlynn PS should have a new one. I got one thru Carter & Gruenewald (www.cngco.com) several years ago.
Probably the easiest way to replace is to knock the roll pins out of both coupling halves. Then unscrew the bearing cap on the front of the steering box and rotate/slide the steering worm & shaft forward an inch or so clear the coupling.
Note! There are TWO roll pins in each coupling half - a small one one nested inside a larger one. Be sure to replace all the roll pins with new. Don't cheat and use a single large pin in each coupling half. Otherwise you risk shearing a pin and loosing steering when it is most needed. (Don't ask how I learned this...!)
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
