Re: IHC 454 front loader capacity
Posted by peter123 on December 26, 2009 at 13:48:37 from (84.1.103.178):
In Reply to: Re: IHC 454 front loader capacity posted by jimb2 on December 26, 2009 at 06:51:28:
Thanks for the response, I still have a problem which is that I have some 500Kg hay bails that need to be moved. should my remaining working 454 be capable of lifting this and would it help if I put one bail on the back first, the idea being that a counter balance on the back would reduce the load on the front axel.
By the way the broken 454 has the type of loader which has a heavey plate (about 3/8in thick) joining the rear mount and the front frame and I suspect this helps hold the tractor together. The other loader does not have this type of construction.
