Re: Farmall 300 head
Posted by Owen Aaland on December 27, 2009 at 02:12:17 from (65.165.246.148):
In Reply to: Farmall 300 head posted by Highland boy on December 26, 2009 at 13:02:38:
The 300 head uses just one washer under a stud. It should be on the stud that goes through a pressed in pipe in the head. If you look closely you should be able to see which hole in the head has the pipe installed.
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
