Farmall 300 head
Posted by Highland boy on December 26, 2009 at 13:02:38 from (142.68.102.88):
When removing the head I noticed one nut had a washer under it. It was located in the middle on the manifold side. Should this be there? Maybe someone didn"t have the the stud turned all the down? I also noticed no valve seals. Does this engine not use valve seals? I took the engine apart to replace the rings, but ended up finding 3 cracked pistons. 2 at the skirts and the other was cracked from the skirt all the way up to the top of the piston. Thanks.
