Re: Alternator touching valve cover?
Posted by farmallhal on December 27, 2009 at 16:53:16 from (71.1.111.67):
In Reply to: Alternator touching valve cover? posted by Zachary Hoyt on December 27, 2009 at 14:30:28:
What 12V alternator is installed on your H? If it is a Delco 10-SI you can gain more clearence with a Hitachi #14231 alternator as they are about an inch less in diameter. If it is the Delco 10-SI you will just need to install a rubber cushion as noted in the earlier posts between the alternator and valve cover unless you want to change alternators. I have the Hitachi on my H with clearence and enough space to adjust the original belt for a tight fit. Hope this helps and if you want further discussion my email is open, Hal.
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
