Re: Super A starter not engaging?
Posted by JRamsey on December 27, 2009 at 19:55:08 from (216.106.48.195):
In Reply to: Super A starter not engaging? posted by Cue P. on December 27, 2009 at 19:41:33:
Could be the bendix drive needs oil on the shaft or, it could be so bad that the drive needs replaced. It would still need lubrication either way and should work. Usually if the bendix drive is really dry on the grooved shaft it will tend to not retract especially if the battery is low and just engages the flywheel and grunts so to speak. I usually have to take the time to take the starter off and then pour a little oil on the groove that the bendix travels in and then remount to the tractor, then it will work.
