Posted by kevin baird on December 29, 2009 at 18:47:41 from (75.106.96.58):
This may be long but hope someone can help. I am work on and Super M with when purchased had a loader on the front with power supplied via a live pump. High pressure run to a cobbled valve set welded to the light bar and a return was piped back down to the port on the right side of the tractor. The return to the live pump was plumbed from the drain plug by a loose hose under the tractor to the live pump. Looked like crap.
Purchase a control valve from an M with a live pump. Which mounts off the fitting for the fill tube. Ran high pressure supply to the inlet of the valve. Thinking that if system is not operating a plow or something the fluid returns to the belly pump. Also I found the guts had been removed from the belly pump so now just is just a tank. I switched the return line from the drain plug to the same plug that used to be the return from the old valve system noted earlier. To make this work inside the pump I drilled and taped this port and added a tube to about 2 inches from the bottom of the tank.
Worked good until I noticed the belly pump tank is hold press causing some little drips and leaks. I found the vent was plugged and after correcting that problem by removing the screw in it when I started it back up I got a big time spray out of the cap covering everything thing. What should I do know to fix this pressure issue in the tank?
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
