Re: Hydraulic oil spraying out the fill cap
Posted by mkirsch on December 30, 2009 at 05:11:43 from (64.80.108.55):
In Reply to: Hydraulic oil spraying out the fill cap posted by kevin baird on December 29, 2009 at 18:47:41:
Using the 2-way valve, you should be using a NON-vented fill cap.
Suction should be off the bottom of the belly pump. Return should be through the fill pipe, out the bottom of the 2-way valve.
