Re: IH 464 can't keep running.
Posted by dannyra on December 30, 2009 at 08:32:04 from (174.39.231.182):
In Reply to: Re: IH 464 can't keep running. posted by El Toro on December 30, 2009 at 08:17:06:
The implement removed the shutoff and put in a plug with the regular adjustment in it and it didn't make any difference. They also took off the carb and cleaned it. They said it wasn't dirty which is expected as we cleaned it several times trying to hopefully get something to come lose that we missed the time before. The mechanic even used a thin wire to go through the main jet and said it was clean.
They also replaced the shutoff with a new one to make sure.
The mechanic seems to also think the carb is the problem and wants to put a new $400 one on it. I just don't see what can be wrong with this simple carb.
