Re: 1977 Int'l 2400 series b gas tractor won't start
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by twopop on April 27, 2000 at 19:08:42 from (208.209.103.55):
In Reply to: 1977 Int'l 2400 series b gas tractor won't start posted by John Kent on April 27, 2000 at 10:02:27:
The part about it turning over faster than before,makes me think timing as you mentioned.I believe you should take a compression test and/or take of the valve cover and then crank the engine to see if the valves are opening.you may have striped the timing gear or it could have broke.
Post A Followup
: Re: Re: 1977 Int'l 2400 series b gas tractor won't start
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
