When an engine won't slow down, the flyweights aren't being allowed to do their job. Freedom of movement is the key. Make sure the weight pivots, thrust bearing, thrust sleeve, cross shaft, and yoke operate smoothly. Also, another area to check is the tube between the governor and the carburetor. My '47 H would surge at an idle sometime and that tube was so full of dirt and crusty scale that the shaft was hard to turn. It seemed that the butterfly (throttle) shaft had worn and the resulting vacuum sucked dust and dirt into that area. There is a felt washer that is supposed to seal this off and it was long gone.
I'm not sure what happened to your H, but the above comment still applies. Good luck.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
