Posted by pete 23 on December 31, 2009 at 10:24:01 from (173.87.0.174):
In Reply to: 5088 Transmission posted by Pittsjock on December 30, 2009 at 06:55:04:
First off, you have about 40 gals of hy tran in that machine, the dip stick is difficult to get a good consistant reading on so I would start there. Check after it has been shut off for several minututes. Forty degrees should not be a problem if filters and fluid is full and clean. Your main clutch may be somewhat difficult to release, there fore grinding of gears due to all the lube oil that is thrown on the clutch during release. Lube valve had a change made on that to relieve that problem. You need to observe the sentry lamp and become acquainted how it works under normal conditions. If it is working normal and you have a no drive I would not attempt to drive it until it is warmed up enough to go. If sentry lamp is showing a problem you won't hurt it as it just won't drive. If power steering etc works it would be safe to just let it run for a while to warm the oil.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
