Re: IH 480 disk doesn't leave the ground level
Posted by dboll on January 01, 2010 at 20:37:12 from (64.61.211.236):
In Reply to: Re: IH 480 disk doesn't leave the ground level posted by John A. on January 01, 2010 at 19:49:12:
chop stalks, disk first time then disk final pass and pull a 5 section spike tooth drag behind it, doesn't matter what you disk it leaves ridges, original owner said it was a 1974 and it came with 22" blades and 9" spacings, once had a 20' 252 Oliver, didn't cut near as good but left the ground level, don't see why the 480 won't if set right.
