dboll, I know there still must be some variable that is being missed. So far I haven't hear you say anything about how you have it set. It still sounds to me like you need to flatten out the Angle of the rear gangs. That combined with shallowing out the rear of the plow should take care of it. Those are the only two calibrations a tandem disk has to stop the plow from ridging. Do you carry any weight on the spike tooth harrow? Try a R.R. Tie on each section! I realize that soil type and moisture and amount of trash still present will have a direct response to how well this will work. Yes, the dryer the soil is the better it will work. These are High Plains Sandy Loam and Central Texas Black Clay tricks. When I was still in the Panhandle of Texas and Okla. Our last pass after we finished disking, we would pull a 30 ft section of R.R. rail to take out ridges and flatten out the field before we Listed (Bedded) it up to plant. Works the same when planting flat too! Hope this helps. Later, John A.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
