Guys, Thanks for all the tips and suggestions. Mattofvinings - I don't have a lathe so I didn't have any way to expand the size of the hole in the plate. TractormanNC - I tried to find a part number for the cover plate, but none of the parts diagrams for the Super A, 100, 130 or 140 even showed the plate my tractor came with. Pete7 - I looked around for a seal that would match the opening but came up empty.
However, I did come up with a solution that seems to work perfectly. I was able to find a NAPA seal with the right ID and close on the OD to insert into the bore in the final drive. This seal is NAPA #18136 with an ID of 1.813" which is the exact size of the seed plate drive and an OD of 2.786", which is damn close to the bore in the final drive. I put a little RTV around the lip when I pushed it in and I am sure it will stay tight and leak free. The cover plate hole fits the outer rubber lip on this gasket perfectly, although you don't even need to use the cover plate. I thought it would help reduce the dirt buildup and kept it. I think this should work for Super A's as well.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
