Re: 1066 Standard Wide Front End Overhaul
Posted by LBSMJS on January 03, 2010 at 08:28:39 from (67.55.148.10):
In Reply to: 1066 Standard Wide Front End Overhaul posted by Michael Sheik on January 03, 2010 at 07:30:33:
I pull them out & put on stands.When you grease the center pivot raise the front end up to let the grease get around to the bottom of the pin.You gone this far just as well check spindle bushings & thrust brgs also.
