Posted by garyandnancy on January 03, 2010 at 11:20:43 from (64.136.26.230):
In Reply to: Cub ignition posted by garyandnancy on January 02, 2010 at 12:55:56:
OK, got it figured out, it was very strange. The governor /mag drive gear was not correctly timed. Pulled of the front of the tractor and then pulled off the governor. It seems that whoever had the tractor apart did not time the idler correctly as it’s marks were way off. Not wanting to deal with the crank pulley, we set the engine at TDC on ##1 and then inserted the governor gear so that its timing mark meshed with the teeth on the idler. Put it back together and presto, it started right up. Thanks for your help.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
