Posted by garyandnancy on January 02, 2010 at 12:55:56 from (64.136.26.230):
OK, I have a very confounding cub ignition problem. I’m working on a Cub that I have never heard run. When I crank it, it sputters but nothing will not start. In diagnosing the issue, the timing is way off, the points seem to be opening exactly when they should be closing so the spark is very late.. The tractor has a magneto type of distributor on it but an external coil has been added. I’m thinking that one of two things is wrong. Either you can not convert from magneto to coil just by unhooking the magneto from the points and installing a switch tot eh battery, wiring it to the coil, and then wiring the coil to the points. This would suggest that while coil ignition fires when the points open, magneto ignition fires when the points close.
The other possibility I have in mind is that the magneto drive is somehow not correctly installed. Right now, with the distributor/magneto off the tractor and #1 cylinder set at TDC, the magneto drives lugsslots point exactly up and down.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
